TedO
- Dec 17, 2001
I have a SVS 16-46cs+ subwoofer being driven by a Samson S1000 amp. I would like to build a subwoofer to pair with it and I have a few questions. I want it to match (or better) the Plus's output and frequency curve. I will not be able to make it look like the plus.
1) Which driver is a match for the driver of the plus?
2) The Plus has (3) 3" flared ports about 32" long. Could I use one 6" flared port instead, and if so how long should it be?
3)I know the "ideal" position for the second sub would be in the same corner as the Plus, but it has to go in the opposite corner (WAF). The room is 16'x24'x 8', How much will this placement hurt the preformance of the set?
4) I have seen some sub builders use 2-3 threaded rods to hold the whole SonoSub together. Is this recommended or is glueing the end caps on sufficient?
5) What material can be used with flared ports? Do they accept PVC, I see the SVS uses some kind of cardboard. I see you can buy them with extensions, but a 3" flared port kit with one extension would run about $25.
OR should I just sell my SVS and build a set of Sono Subs?
