SVS Calibration - newbie question (1 Viewer)
Brian Elwood
I was running the 20-30PCi through Avia and noticed that around 70Hz the SPL dropped off, then came back at 60Hz.
Is there a way to fix that? Is that crossover?
20Hz? perfect, and AWESOME!
I place the monolith in 4 different spots and this seems to be the best . . .at the moment.
BTW - new stands are next and after those you will start hearing questions about new surrounds.
Allen_N
It could be the crossover. What do you have it set to? It could also be room issues. I would try setting it to 80hz.
Edward J M
Try adjusting the phase control and re-running the Avia sweep. Try 180, and 90 first. Then try to hone in on any possible sweet spot in 15 degree increments. Some drop-outs can be corrected with phase; others can't.
The only way to really tell what is happening in the room is to plot the FR with some test tones, the SPL meter, and a spread sheet with correction factors.
atlanticshores
