Ed,
Tom might correct me but approx. 19x19x45 and 55 lbs or so (with box. It's quite a box ;^)
Not something you will be thowing in your Miata, or putting up on your shoulder. Once unboxed moving it around is very easy though.
Ron
I would also like to add that I have never seen better packaging than the SVS packaging.
-Dean-
------------------ My HT Equipment "I've seen you and you are not cool."
I just got mine last week. I will say, I used to hear stories of these subs coming wrapped in bubble wrap, which was wrapped in bubble wrap, which was wrapped in a box with more bubble wrap.
Not nearly that difficult anymore. Cool foam padding on the inside of the box that protects the sub and makes unloading it extremely easy. (Mine came in perfect working order...) I think my sub box said 60lbs., but I could be misremembering...
The custom boxing was a life saver for us. Not only did boxing them up take WAY less time (I am talking literally hours less per sub) but our damage rates dropped significantly.
Erik K SV Subwoofers
