svs 25-31 anyone else just not impressed
Discussion in 'Archived Threads 2001-2004' started by David Harris, Feb 25, 2003.
  1. David Harris
    David Harris Stunt Coordinator
    Oct 31, 2002
    51
    A freind of mine just received a 25-31 svs sub woofer and although alright, i was not thouroughly impressed with it, he is running a pioneer pioneer vsx 43 tx and the speaker
    are klipsch quintet, the sub overall is very seems light and boomy. Overall,i dont think i will purchase one for myself, but it may just be setup, because so many people on this forum regard this sub so highly...
  2. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    i would definitely have your friend contact SVS and see if they cant help the problem before you give up on SVS...
  3. keir
    keir Stunt Coordinator
    Jan 16, 2002
    182
    a lot of svs reviews seem to use a lot of hyperbole. besides trying to make the point of the persons first impression, it can give people the wrong idea. i wouldnt take every comment at face value. other than that though, svs subs are pretty damn good performers and if it sounds boomy i would bet its a placement issure or theres something else wrong. also, even a pci should be able to get near reference levels with low distortion. if by "light" you mean thats its weak sounding, i advise popping in something like star wars episode 1 pod race, or the landing right at the beginning of episode 2 (or any other bassy movie). it should be able to sound pretty impressive with the right material. my 16-46 pci sure does.
  4. David Harris
    Oct 31, 2002
    51
    I meant musically, the performance with cinema is truly
    impressive the ultra low bass is also impressive, it just seems soggy arount the middle listening to music...
  5. Bill Polley
    Bill Polley Second Unit
    Apr 18, 2002
    252
    What do you cross over at? I have quintets also and my 16-46PCi blends perfectly with them. I am crossed over at 120hz and run a BFD to EQ the room. With my sub placed between the mains, localization is not a problem, and the tiny Klipschs shine with the sub creating a solid bass floor. By the way, the quintets are all wall mounted...their response is much smoother and deeper this way than using them as bookshelfs away from the wall. Must be in the design.
  6. Robb Roy
    Robb Roy Supporting Actor
    Jul 15, 2002
    711
    David,
    I would guess one of two things is going on here:
    1) The sub is not calibrated/set up correctly, or
    2) You are expecting the exaggerated bloat around 50 Hz so many commercial subs employ to sound more powerful than they are.
    A lot of the descriptions from SVS owners are misleading, in that what we are impressed with is the accuracy as much as the volume. In many instances the SVS disappears where previous subwoofers demanded attention a la the bloat I mentioned above. When called upon, however, the SVS lets you know its presence in frequencies many of the commercial subs cannot even reproduce at audible decibels. What the SVS provides is flat, clean reproduction of low frequency recorded material.
    If number 2, it could take some time sampling movies/music, and if number 1, an email to SVS should clear that up.
    -Robb
  7. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Hi David,
    The performance of any subwoofer will be dictated to a large degree by several variables...
    1)the room size and shape(and the number and size of openings into it)
    2)the seating positions
    3)the subwoofer placement
    4)the crossover used for the subwoofer(lowpass) and speakers(highpass)
    5)the relative phasing of the subwoofer(compared to the rest of the speakers).
    6)the overall calibration levels used.
    I'm not sure who we are tlaking about(I may have his room shape/layout on file already), but if I knew the details above we might be able to get things working better for him. Of course, this just might be an instance of the SVS not being what you expected...which is were the 45 day trial period comes in..[​IMG]
    Please have your friend email me at
    [email protected]
    When he has time and we'll see if we can get things working a little better for him.
    Tom V.
    SVS
  8. Scott Ryan
    Scott Ryan Auditioning
    Nov 20, 2002
    7
    Hey Tom,
    On an unrealted matter....check your e-mail if you get a chance in the next 30 min. I want to see if you think the sub placement I'm thinking of will work. If so, I have to run some cable first thing in the a m before the sheet rockers show up [​IMG]
  9. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    Hi Scott,
    Just did, back at ya...[​IMG]
    Tom V.
    SVS
  10. David Harris
    Oct 31, 2002
    51
    Tom, my freind is very pleased with the svs, i reccomended the sub to him, i helped him set it up and i am the one not impressed, i havent given up on it yet because room placement may be the issue..... the crossover is set at 120hz,it was originally at 80, but the gap was to obvious..
    Maybe it is just do to all of the hype...i expected this
    sub to shine....
    Thanks for all of the responces.....
  11. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    He may want to check the phase. When I first set up my 20-39CS+, I had accidentally swapped the positive and negative leads. Because of this, bass in the crossover range was getting cancelled and I had it calibrated way higher than it needed to be. A few phase tests later, I fixed the problem. Just an idea...
  12. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    Hi David,
    You'll want to use a 100-120hz XO with the small Klipsch speakers I think. Is he using the subwoofer preout of the receiver to patch in the subwoofer? Don't forget, setting the subwoofer crossover to 120hz won't help if the receiver is lowpass/highpass the sub and speakers at 80hz still [​IMG]
    I would expect the SVS to shine too, so if you can experiment with the variables I listed above as time allows I think you'll find things might improve. Of course, doing a simple FR(freq response) check would be invaluable in trouble shooting too. Be sure to let me know (here or in a private email) if there is any way I can help if you start experimenting.
    Tom V.
    SVS
  13. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    I have an SVS 25-31PCi, and I have nothing but positive comments about it.
    I think the Quintets are an entry level speaker, which may or not blend well with the SVS. Maybe he is running the sub to hot.
  14. Lee Bailey
    Lee Bailey Second Unit
    Jun 8, 2000
    263
    Central California
    Lee Bailey
