Judy Y
- Feb 27, 2000
I am assuming that the passive version of this sub, (which I ordered), is like any other passive sub. I would run an RCA cable from the sub out to my amp then run speaker wires from the amp to the sub. Is this correct?
Also, I have a 250 watt M&K powered sub now. If I am using just a surge protector and NOT a line conditioner, is there any reason I cannot plug the powered sub and the amp for the SVS both into the surge protector?? I know that line conditioners typically choke power to amps but, with a surge suppressor only, does anyone see any issues?
Finally, I believe, my amp is 100 watts into two channels 8ohms, (okay, it USED to be, one channel wimped out on me and there is now only one left), would it be pumping more into a 4 ohm load on the SVS sub? (Yes, I plan on getting another, better amp- but I am still trying to pay off the HDTV. Yet, I HAD to have an SVS sub any way I could think to do it!!)
