Suspending Speaker Cables (1 Viewer)
Brett DiMichele
Brett
I have seen numerous people that suspend their speaker
cables on different types of cable trestles. So I got to
thinking (and this usually gets me in trouble mind you).
If suspending the cables makes a difference then does
The type of material also make a difference in what you
Hear? Here are some of the numerous types I have seen
The real audiophiles use.
Maple Sticks
Pine Sticks
PopSickle™ Sticks
Carbon Fiber Elevators
Glass Telephone Pole Insulators
I can think of some other items that would work also.
Lionel Model Train Trestle Sets
Hockey Pucks
Empty Beer Cans (Can’t use full cans that would be a waste of beer)
Used Car Valve Springs
Used Car Valves (Those Retainer Groove would work well for using rubber bands)
Old Shoes? (Preferably non stinky)
Hospital Grade Traction Assembly (Hey if it can support a broken arm or leg)
Semiconductor Magnetic Levitation Devices (EMI Might be an issue here)
Antigravity Generator (Not yet conceived but it’s in the works)
B.T.T.F Hoverboards
Fake Rubber Dog Poo from Spencers (Could also work for component vibration
Dampening)
Can you think of anything else to add to the list? I am sure there are numerous other
Items out there that could easily work as well as some of the commercial offerings
From high end esoteric audio companies. Any input and suggestions would be greatly
Appreciated. Thanks a whole bunch!
Chu Gai
You obviously are going about this all wrong Brett. Any discerning audiophile, who is interested in separation, a firm top end, and a powerful, controlled bass would use something along these lines to elevate the wire.
My apologies in advance to the admins...delete this post if it's inappropriate.
Danny Tse
Chu,
The fabrics on the "suspender" may cause static, so you need to have your "suspender" to be nude. Oh, since I have long runs of speaker cables, I will need several "suspenders". :D
Chu Gai
those might be the only reason to speak ill of a blind test ;) you should know that static's only a problem during dry conditions but perhaps being in California should give you access to a variety of cable lifters at the shore.
Chris Tsutsui
Maybe you should audition wire suspension made of pre-owned victoria's secret thongs model #45-6244. Yet, then there are the people that prefer using childrens Hanes size 4 (age 8-11), but lets not go there.
I heard the newest craze is building a miniature loffel wall for wire isolation out of a muslims molars.
Either that, I hear ppl now use useless spindles of monsters cable as towers, or even acoustic research interconnects they now sell in grocery checkout lanes.
:D
Actually I don't even use objects anymore to hold my speaker wires because I hold them off the ground with my hands, feet, and arms. This way I can elevate them and shake them as I listen to music. The shaking and movement of the cables affect the music much like an orchestra conductor. It may look peculiar from afar, but boy you guys don't know what you're missing.
Brett DiMichele
Brett
Chris,
Vewwy Vewwy Intewesting!
Unfortunatly I usually hold and shake something else with
my hands.. But that is neither here nor there..
Hey don't knock it till you've beat it.. Err wait a minute..
I mean don't knock it till you've tried it! :D
John Royster
I use little tile 3 sided squares (imagine three faces of a cube with a common vertex) from home depot and then just dremmel a notch in them.
Works like a champ.
Brian OK
LAY your carpet first.
Brett,
Use anything that gets the wire off of the static conductive floor ... I suppose that was the point of your post. Drag your feet, without lifting them, touch your pre/receiver and see if that doesn't give you a rise. If not resort to Chu's pic. Elec is just a pass through to wires if you suffer from static charge. Otherwise, I like Chu's pic ... if your system sounds electrical... then look at Chu's pic. All is well ;0)
Brett DiMichele
Brett
Brian,
Lay my carpet? Eww no way, I am not that desperate!
I do get some static in my new carpet that I just put down
a few months ago but beyond that once I get everything with
my system ironed out (that'll never happen) I want to
suspend the cables for a nice clean look and to space them
away from my power cords which currently pass over my speaker
wires (at 90 degree angles, measured with a protractor :D )
I think I may try and find some of the glass insulators off
electric poles.. Since I work for the power company this
shouldn't be a problem :) Then spray them gloss black, lay
the wires on top and gumband them down..
Would look nice and neat, keep the wires off the floor and
look "High End" ;)
(I would rather use Chu's idea but heck I couldn't get one
of those to lie on my floor even if I paid good money for it!)
LOL!
Chu Gai
check the escort services in your local yellow pages where i'm sure good money can be spent for something along those lines :D
Aetherpirate
