SURVEY: How important is flat frequency response to you? (1 Viewer)
Arnel Enero
To me, this is the most important MEASURABLE characteristic that I look for in a speaker. IMO, if this is not flat, you're not really hearing the true timbre of instruments. Because high-end audio is about reproducing the recording with complete honesty, the tonal response should be neutral, doesn't it?
I'm not saying it's the only important design parameter, but definitely it should be the starting point, and is very basic.
Unfortunately, and I wonder why, there are many ultra-expensive speakers that don't even meet this basic criterion. This is not an anti-brand post, but here's some examples:
Sonus Faber Amati - it's got a problematic response-peak in the midbass
Krell LAT-1 - the FR graph looks like a roller coaster ride!
Krell LAT-2 - midrange response is prominent, then shelved-down below 500 Hz
Wilson WP6 (and most other Wilsons) - through its many iterations, this "monitor" speaker never really achieved monitor-quality flat frequency response... its FR graphs always being rather rough. Then there's a bass lift centered at 100Hz, and above 15KHz, it's got serious dip and then peak!
Why can't ALL speakers that cost above $5000 at least level with the well-behaved FR of really "honest" speakers as Revel, B&W, JMLab and Dynaudio, for example?
So does all this matter to you at all?
EricHaas
I tend to take a flat FR for granted. Obviously, if it isn't there, like Bose with its +/-10 dbs, then I wouldn't even consider the speaker. But most mid to hi-fi speakers have relatively flat FR's, so I tend not to give it too much thought. Bottom line, it all comes down to listening...
Jeff D.
Jeff
Relying on frequency response measurements is essentially useless. Forget the fact that frequency response does not even come close to telling the whole story (most current amps and CD players have very similar frequency responses yet have totally different sonic characteristics), but you are forgetting the most important part of your system.
That part is the listening room. Every room is different and will change the frequency response of any given speaker. So even if you found a speaker with a flat frequency response, once you put it in your listening room all of those flat lines would be moot.
/Jeff
Brian Fellmeth
A flat FR is over rated and impossible to acheive anyway. Not only does an untreated room mess up what would be flat in an anechoic environment, but whats even worse than that- your ears are not flat ! Everyone's individual audiogram has peaks and valleys. To hear something truely flat, you would need to plot your audiogram and use an equalizer to shape the signal to the inverse.
Arnel Enero
But these ears I have are the SAME ones that hear real instruments in a live concert... which is the "reference" sound to tell what audio system sounds more real. I think that's the goal... for our INDIVIDUAL ears to perceive the sound from the system, through the speakers, to be the same tonality as what we hear in live concerts, and NOT necessarily absolute flat FR. Alas, in this case, the speakers as well as the rest of the system (room included) still NEEDS to be flat response.
I'm not invalidating your opinions here, but I'm just trying to explain my side of the equation. But in the end, it's still an equation, where everyone's opinion is as good as the rest. :)
Michael R Price
I've got to agree with Arnel. While we all have different ears, real music does have a "flat frequency response." I'll stick to my +/-3dB.
Jeff D.
Jeff
perfectly said:
Very simple. They have realized it is not as important as you are making it out to be. Instead, they have built their success not by obsessing about specifications, but listening to the product they build and improving it that way.
I honestly think shopping for any audio equipment by specification alone is a true sign of someone who doesn't appreciate what the system is all about. Listen with your ears and throw away all the preconceptions that come with specifications. You'll learn a lot.
/Jeff
Bhagi Katbamna
I think it is a good starting point but a lot depends on how the speaker is measured. If you look at the measurements of electrostatic speakers, they look not too great but they actually sound very good. That being said, if two speakers are measured in the same manner, and one has serious FR abnormalities then it is probably one that would go lower on my list to audition. Many times, a brief audition will not reveal FR abnormalities if they are over a limited range of frequencies and may be audible only with certain material. That is why home audition should be prolonged.
EricHaas
I have to disagree with Jeff on 2 points. No doubt, a room will defeat a flat response curve everytime. However, speakers with wild curves will generally be worse in a given room than speakers that start out flat to begin with. Better to start out with something close to perfect before adding room interference than to start out with something like Bose. Also, although you cannot get an acoustically perfect room, you can do things to your room to reduce the degree of room interference with the FR. Sometimes it may mean adding acoustic tile, or something as simple as moving a piece of furniture or moving a speaker. The goal is never a perfectly flat FR because that is impossible outside an anechoic chamber. It is to have the best FR possible under the circumstances.
I do agree that there is much to a speaker that is not told by the FR, which is why FR is a starting point only. However, no serious audiophile is going to say that it is *totally* irrelevant whether a speaker is +/-10 db or +/-2 db around its useable frequency spectrum.
Sebastian
IMHO, I believe that a flat FR in speakers is very important. As for peaks and valleys are concerned, that is what an EQ is for. Creating peaks or valleys at a certain frequency until you think it sounds good. Who wants a roller coaster speaker to start of with? Especially when the room acoustics are going to be messing with the FR to begin with.
I don't think he meant "specs alone", more as a starting point. You can tell a lot by specs, like quality and longevity of the equipment and the engineering that went into making the equipment.
If you do not shop around for specs you are lying to yourself. So you mean to tell me that wattage does matter to you, the size of your speakers or THD?
If you do not have an idea of what specs to look for than you are a sales person dream.
I am sure when you were buying your HT equipment you had some sort of guideline to follow. If you did not I have some very good sounding equipment for sale:D
You are right in one aspect, if it sounds good to you and you are happy with it that is all that matters.
Michael R Price
Your ears can tell the difference between the initial sound coming from the speakers and the reflected sound coming from your room (except bass). A speaker with a perfect anechoic frequency response making the sound of a piano in your room will sound like a piano in your room. If you make deviations in frequency response, the initial sound you hear coming from the speaker will be inaccurate.
So I don't think arguing that the room makes frequency response invalid is a good idea.
jehremy
Grip
Didn't Harman Int. conclude that in their blind listening tests that listeners prefer a flat FR and that it was the most important factor in choosing what they thought was the better speaker? IMHO it would be nice to audition all speakers in blind conditions, but we know dealers would never set it up due to the fact that they would lose sales on higher priced speakers.
Jeff D.
Jeff
sounded good said:
What!?! Find me a speaker that has a perfect frequency response, then perform blind tests in 100 completely different rooms and tell me if your listeners think it is the same speaker every time - it ain't gonna happen. The room is the most important part of your system, period.
/Jeff
Sebastian
Yeah, typical sales person trying to talk you out buying good quality speakers and what you want to buy. J/K
Let talk subs specifically. You still do not look at the specs?
Lets say we have a sub tuned to 25 HZ and it sounds awesome but 60 to 80 Hz it sucks, (not as loud). there is another sub that is also tuned to 25 HZ and is rated at +/- 3DB it sounds awesome across the whole frequency range 20Hz to 120 HZ or whatever.
Which one are you going to choose?
The second sub right? because it sounded good to your ears, right?
but why did it sound better to your ears? because it has a flat frequency response and the other one does not. Specs do mean a lot but if the a speaker has the best specs in the world and you hate the way it sounds, who cares about them.
Usually a sub that has good specs usually sounds good. I personally use specs as guideline for buying stuff, but if I don't like they way it sounds, I am not buying it.
:emoji_thumbsup:
Lee Scoggins
Atlanta, Georgia
Lee
This thread has proven once again what I see day in and day out in our audio store. We do not sell any piece of equipment because of some spec. We encourage our customers to listen to the music. Do you like it? Buy it. If not, keep listening until you hear something you like. I guess it might be satisfying for some people to boast because their system has perfect frequency response and no distortion - but guess what, that bores people to tears. When people come to my house they stop talking and listen to the music. That says more than anything.
Amen Jeff.
Look at amplifiers, some of the best sounding amps suck from a measurement standpoint.
By the way, better than flat response, the new waterfall graphs that Stereophile has been creating have far more descriptive power with respect to sound.
Here are some equally (if not more) important speaker features to look for:
(1) high quality tweeter and midrange
(2) internal wiring of quality like Cardas
(3) if box speaker, rap on the side with your knuckles, if you hear more than a dull thud, the internal bracing is lacking
(4) ability to display detail in the notes
(5) ability to create a realistic soundstage
(6) sturdy (WBT for example) cable connections
(7) if planar, the name Magneplanar on the back ;)
(8) fit and finish, usually highly correlated with all else
(9) bi-wire ready terminals
(10) good grounding to the floor (spikes, etc.)
(11) find a dealer that will let you take them home, cause most dealer setups and geometry within the room are terrible
Norm Strong
Frequency response is quite important. It's one of the few ways to rate a speaker. And a way that doesn't require a golden ear.
It has not escaped my notice that audio professionals, who make their living based on their ability to separate the good from the great and the poor from the execrable will never be caught making public comments on the sound of any piece of audio gear whose identity they do not know. This goes for speakers, amplifiers, CD players, and especially wires. The chances of looking ridiculous are just too great.
atlanticshores
