Surrounds that switch between monopole and dipole list please
Discussion in 'Archived Threads 2001-2004' started by Steve*MH, Sep 8, 2002.
  1. Steve*MH
    Steve*MH Stunt Coordinator
    Aug 12, 2002
    76
    Looking for a list of surround speakers that allow you to manual or remotely switch the speaker from monopole to dipole and vise versa for different applications. The debate is ongoing about the use of monopole vs. dipoles for movies and music, and it would be nice to have the choice between both rather than deciding betweeen a strictly monopole or dipole speaker for a set of surround speakers(either side or rear) as opinions and surround formats change in the future. Thanks for any contributions to this list.
  2. Frank Zimkas
    Frank Zimkas Supporting Actor
    Mar 10, 2002
    888
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I know M&K also sell a TriPole speaker.
    But you really want to avoid these "gimick" speakers.
    Here is the problem: even if they worked as well as they claimed, you need to:
    - Mount them differently for each style
    - Calibrate with different numbers for each style
    Dipole - you mount these to fire along a wall so the listener only hears indirect sound. They often need to be turned up louder to mate with the front speakers.
    Bipolar - these should be mounted 2-3 feet into the room to give the rear-fire sound some time delay. These are a direct-radiator so they often dont need the extra volume of a dipole.
    Direct/Monoploe - These are the simplest to setup and use, and minimize the use of nearby walls. Dont forget that you want to allow for 3 of these: one for that rear-center speaker. And this is the type of speaker many studios assume you have, including all the new audio formats like SACD/DVD Audio.
    So the complexity of correctly using each make it more trouble to flip that switch than it is worth IMHO.
  4. Charles Shultz
    Charles Shultz Auditioning
    Sep 6, 2002
    8
    i believe the boston VR series surrounds are switchable.[​IMG]
  5. Han
    Han Second Unit
    Jan 13, 2001
    262
    DefTech's got some that switch between mono and Bi.
  6. Rich X
    Rich X Stunt Coordinator
    Jun 18, 2002
    115
    They are pretty expensive, but both Aerial Acoustics and Revel make surrounds that can switch between bi/di/mono. The Aerials have a remote control and I think the revels can be switched either manually or with a 12v trigger.
  7. ChrisJJ
    ChrisJJ Agent
    Jun 4, 2002
    33
    Also, Cambridge Soundworks S-300 is Bi/Di/Mono switchable.
  8. Steve Morgan
    Steve Morgan Second Unit
    Nov 10, 1999
    328
    Farm in Kansas
    Steve
    Take a look at the Von Schweikert Audio Tripole TS 350. Comparable to the Aerial at a reasonable price!
