surrounds on 4 channels ?
Discussion in 'Speakers' started by Mike F, Feb 1, 2004.
  1. Mike F
    Mike F Extra
    Jan 16, 2004
    17
    I would like use the surround speakers for the 2nd pair of mains. Because I listen to alot of music I would like to connect the surround speakers to the number 2 main channel outputs as well as the surround outputs .Any suggestions ?
    Can I just connect the speaker wire to 2 outputs or do I need to get some sort of switch ?
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    hrmm what receiver are you using? you can get the same effect without swapping channels by using Dolby PLII. I wouldnt suggest connecting the wire to 2 outputs i would think that would damage your system.
  3. Harold Wazzu
    Harold Wazzu Supporting Actor
    Oct 1, 2003
    885
    I think most receivers have a DSP mode called "6-channel stereo" or something along those lines where all of the speakers drive the same stereo signal.
