John-e-s
- Mar 22, 2002
Hopefully someone out there has the answer for this one. I have two fronts, a front center, then three additional speakers--two identical rear-type and a center-type. Without the extra center type, set up is obvious--hook up the two identical speakers as rear surrounds. However, if I want to use the rear center, my receiver (B&K307) requires I hook up the two identical speakers as surround L&R (not rear surrounds), then use the center type as a single rear surround speaker, to which both R&L rear signal will be sent. Which is better--just going with 5.1, or having 6 speakers, but with a non-split rear? Am I losing more by not having split rear signal and having R&L surrounds (which by the way are behind the listener in my set up)? I haven't opened the rear center, and I could just take it back and get two speakers for rear surrounds and have 7.1. Thanks in advance for any Thoughts
