GregBe
- Jul 9, 2003
I am going to be purchasing a set of M&K 850 speakers for my L/C/R. (these each have two 5 1/4" drivers in them). Because of my room arrangement, I am down to two choices/locations for my surrounds in 5.1, but each one has its downsides so I am trying to decide the lesser of two evils.
My room is relatively large at about 19' x 19' x 8', and I sit about 4' from the back wall.
1) purchase the 650 bookshelf speaker which is the technical perfect match for the 850 with the exception of 1 driver instead of two. If I go this direction I will have to place it against the wall with an omnimount on the side walls, but they would pretty much need to be up in the corner where the two walls meet the ceiling. I pretty much angle them in any direction, but they would be in the corner all the way up near the ceiling.
2) purchase the M&K K4 surrounds which is their tripole model that has gotten good reviews. The good is that I can place them in the ideal location which is on the side walls directly to my sides and at any height I choose (because they are smaller, I have more flexibility with the WAF). The bad is that they are smaller. They have a 4" driver and a 1"tweeter facing out, and two 2 1/2" drivers facing front and back in a dipole arrangement.
Which way would you go?
Greg
Greg
