TheLongshot
- May 12, 2000
- Jason
Gotta love the forum. You know when you type in a really long post, and the forum hickups and loses all of your hard work. Ok, I'm going to try again...
I just bought a pair of Paradigm Titans to use a surrounds in my new place. The problem is where I'm going to put them. One thing I do know is that they have to go on the walls, since I have no floor space for them (why I got the speakers in the first place) and the ceiling is concrete. It will be close to the ceiling since I have a patio door on one side. The problem I'm having is on the other side, where the wall goes back about 10', then turns away for the door to the first floor. For Example:
|*F**C**F**| Ch = Chair
|**********| F = Front Speakers
|**********| C = Center
D**********| S = Subwoofer
D**Ch*Ch***| D = Door
D**********|-D-|
D**Couch*******|
|**************D
|*S*Equipment**|
Edit: Damn, I thought I was going to get proportional spacing if I selected Courier....
The problem with mounting the right speaker on the wall is that it sits between the front chairs and the couch. My understanding is the surrounds should be slightly behind the listeners on the sides. Well, that isn't going to happen in this room. So, my options, as I see them:
1. Make the compromize and put the speaker on the wall, knowing it will be between the chairs and the couch.
2. Building a shelf on the wall where the door to upstairs is and putting the speaker on that. That will put the speaker in-line with the couch.
3. A suggestion from the dealer (after he tried to sell me dipoles that cost twice as much), to mount them on the back wall.
Personally, I like #2, but I want to hear other people's ideas...
Jason
D**********|-D-|
D**Couch*******|
|**************D
|*S*Equipment**|
Jason
