Lando P
- Apr 15, 2002
On my AVR-510's front panel surround mode indicator, the "Dolby Digital" light would stay on only for a couple of minutes after I turned the receiver on. Then the light would go off while the rest remain lit.
The unit's still under warranty, but the wait of 10 - 14 days plus the inconvenience of taking out and putting back all the cable and wire connections is just too much for a supposedly minor problem like this.
Has anyone had a similar problem? Or does anybody have any idea whether this could be a DIY fix? I would appreciate your input.
Regards
Regards
