Surround Height (1 Viewer)
Louisp
North Texas
Louis Patrick
Please settle this issue for me. Should surround speakers mounted on the side walls be placed at ear level or 2 to 3 feet above listening position level.
Ilkka R
Ilkka
I believe Dolby says 2 to 3 feet above. But you know that's not the law...
Brian L
First, this is a topic of debate, so if you are looking for a definitive conclusion....sorry!
For film, higher up would by optimum.
For MC music where the rears are just ambience, higher up would also be a good choice.
But if you like MC music where there are instruments placed in the rear channels, then for me, ear height is the way to go (I mount the rears a bit behind and to the sides of the seating position).
I was OK with high mounted surrounds until the day I bought my first MC music disc with discrete instruments panned to the rears (Steely Dan - 2 Against Nature). Having saxophones and vocals coming at me from up high just did not work for me.
You can argue that having instrumants behind is phoney to start with (point taken), but for me, behind and up high was just too phoney.
Its been my experience that a rig set up as I currently have mine works OK for films, while being superior for MC music.
YMMV. IMHO. AFAIC.......
BGL
Will d s
I would go with about 18in above ear height. If it is set right at ear height than the people sitting in the middle do not get very good sound since it is being blocked by the people on either side.
S205449
