Surround Connections for 2 Channel Music (1 Viewer)
efgillis
Edward Gillis
I would like to connect four speakers, one in each corner of a 25X25 square room, to a Sony STR-DE685 receiver for 2 channel music only, 2 left and 2 right connections. The A speaker connections are for 5.1 sound and the B connections are just 2 channel stereo. A and B cannot run at the same time. Can I or should I use the surround connections to add 2 more speakers OR can I connect 2 speakers to each A output OR should I buy another receiver. Thanks in advance for any advice/suggestions.
SethH
I would connect them to the surround channels and then you can run your receiver in "5-channel stereo" mode when listening to music. Most receivers have this mode, although it may have a different name.
vertigofilmfanman
