Surround Back Placement Height
Discussion in 'Speakers & Subwoofers' started by Louisp, Jan 2, 2005.
  1. Louisp
    Louisp Stunt Coordinator
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    In an ideal situation is it better to mount surround back speakers at the same height as the surrounds?
  2. stephen shadow
    Aug 6, 2004
    38
    Yes[​IMG]
  3. Craig Ball
    Craig Ball Second Unit
    Oct 6, 2000
    278
    I think it would depend on wether or not there direct radiaiting or dipole.
    Craig
  4. allan espinoza
    allan espinoza Stunt Coordinator
    Jul 1, 2002
    210
    i dont. is it 6.1 or 7.1?
  5. Louisp
    Feb 23, 2004
    169
    North Texas
    Louis Patrick
    The speakers are direct and it is a 7.1 setup.
  6. allan espinoza
    Jul 1, 2002
    210
    where is your ht setup? is it in a dedicated room or living room? i have my side surrounds mounted on the side wall six feet up and my rear center surrounds i have them on speaker stands behind my couch facing up and all i have to say is, wow!!! I read that tip from another member on this forum who said that he placed his rear surrounds behind his couch on the floor facing up, but i didnt feel too comfortable placing my speakers on the floor so i went ahead and bought speaker stands that were 16" and placed them on top facing up. try it you never know and plus i get responses from people who dont end up seeing them say, "why does it sound like there are more speakers behind me?" my favorite reaction is when they try to localize the sound and see where it is coming from.
  7. allan espinoza
    Jul 1, 2002
    210
    oh yea, my speakers are direct as well.
  8. Craig Ball
    Oct 6, 2000
    278
    My side surrounds are about 6' up also these howerver are dipole design and that's where they should be placed if possible, if my rears were dipoles i'd do the same in the rear but they are direct radiating and i have them on stands so that the tweeters are at the same height as the mains. This is the best set up IMO.
    Craig
  9. Ernesto.Morin
    Ernesto.Morin Stunt Coordinator
    Jan 28, 2003
    179
    allan...Our your running a 6.1 setup or 7.1? It sounds like 6.1.
  10. allan espinoza
    Jul 1, 2002
    210
    no im running a 7.1
  11. Ernesto.Morin
    Jan 28, 2003
    179
    Cool. How far apart did you place your rears behind the couch?
  12. allan espinoza
    Jul 1, 2002
    210
    i have the rears at each end of the couch. i am not at home right now so i cant measure to give you an exact estimate, but i have them at each end so that no matter where you sit on the couch, you will be in the middle of both speakers. i really suggest you try it. i turn up the rears by 1/2db from calibration just to give it a bit more push and it worked out great. all surrounds blend in very well and you really notice the transition from the side surrounds to the rear.
  13. Ernesto.Morin
    Jan 28, 2003
    179
    Thanks that works. I am going to try it, will post back feedback.
  14. allan espinoza
    Jul 1, 2002
    210
    good luck!!! dont forget to recalibrate.
  15. Craig Ball
    Oct 6, 2000
    278
    allen, you have your direct radiating speakers on stands behind your couch facing up? So there on there backs facing up towards the ceiling. Why don't you have them facing forward? or am i reading your post wrong?
    Craig
