sam37
Grip
- Jul 29, 2008
- Sam
I don't know if it is just me being very very overly picky, but is it possible that a surge suppressor can have an effect the audio/video quality of your entertainment system?
For example, I have an RCA surge suppressor, not sure if it has filtering in it. The other day, I went and bought a Monster Power surge suppressor that has the signal filtering in it. When I plugged it in and turned everything on, I noticed something. It seemed that my picture quality had gone down a little, the picture didnt seem as clear and wasn't quite as bright, the bass from my sub didnt seem as loud or vibrant. I took it back and bought a Dynex strip, with the same type of filtering, and it "seemed" to have the same effect.
Has anyone heard of anything like this. Is it possible that the power strip you use can have such an effect on your equipment, or is it more than likely it was all just in my head?
