Surge protector/audio quality?
Discussion in 'Home Theater Projects' started by ericMM, Sep 8, 2005.
  1. ericMM
    ericMM Extra
    Aug 23, 2005
    19
    I'm about to use a very cheap six outlet surge protector for my upcoming dorm audio system (CBM-170's, denon 60 wpc, etc). Could this lead to worse performance than simply plugging the equipment straight into the wall? Should I invest in something like a monster surge protector (i get something like a 60% discount because my last two jobs had me get "monster certified"?
  2. Phil A
    Phil A Producer
    Oct 1, 2000
    3,170
    37
    Central FL
    Phil
    If it restrcts current, you could lose some dynamics plugging stuff that draws current (e.g. amps). Try it with and without it after you have the system set-up listening to your favorite discs.
  3. ericMM
    ericMM Extra
    Aug 23, 2005
    19
    It states "15 amps" on the back. That sounds like an aweful lot of current so it'll probably be okay; nevertheless, I'll do a comparison with the actual equipment to make up my mind.
  4. Phil A
    Phil A Producer
    Oct 1, 2000
    3,170
    37
    Central FL
    Phil
    It may be rated at 15 amps but may see a demanding piece of music and mistake it for a surge and repress the dynamics.
  5. chris_everett
    chris_everett Second Unit
    Jul 20, 2003
    403
    If you have a dorm system that actually pulls 15 amps of power, you'll probably get thrown onto the street so fast your head will spin.
    Any decent amps should have a good enough power supply that it won't make anything like a "surge" on the line. If it does, you'll blow the breaker (maybe), But it's not going to do anything with a surge suppressor. If you have a 60% discount on monster stuff, I would use it on the cheapest one they have with enough outlets for your gear. But it won't help/hurt your sound.
