Surge protection/power conditioner
Discussion in 'Home Theater Projects' started by Kevin_F, Feb 23, 2005.
  1. Kevin_F
    Kevin_F Stunt Coordinator
    Dec 1, 2004
    246
    What type or brand of either surge protection or a power conditioner do you guys use?
    Is there a difference between the two?
  2. David Noll
    David Noll Stunt Coordinator
    Aug 31, 2004
    228
    Kevin,
    I'm using a Panamax MAX 5300 surge/line conditioning system.
    This unit does both. Isolates all incoming/outgoing lines and all equipment in the theater from lightening and surges. Conditions power and is programmable for both low and high voltage shut down. It also improves audio performance, particularly bass response. Highly recommended.
    Dave
  3. Bryce_H
    Bryce_H Stunt Coordinator
    Oct 20, 2004
    120
    10
    Just bought a Pananmax 5510 to suppliment the panamax 550 I've had for about 5 years. the 550 will be for the living room setup and the 5510 for the dedicated HT I'm building in the basement. Have loved the 550 which sold me on the 5510.
  4. john.michael
    john.michael Agent
    Aug 23, 2004
    28
    How do I mesure the size of the power conditioner? I will be using a Lexicon NT 512 (5x120w) and a Lexicon NT 212 (2x120w). Calculate about 25A draw of power.
    Should I use a voltage regulator as well?
    How about a no-break, any recommendations (I have lots of brown outs and black outs in my place).
  5. Andrew Stoakley
    Andrew Stoakley Stunt Coordinator
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hey John,
    I use a Panamax 500 and it works just fine. I have it plugged into a dedicted 15amp circut directly from my panel. I've never had any problems with dirty power or surges. However, I did not run my cable line through the cable protector as I found it did add colouration to the signal.
    Cheers,
    Andrew
  6. Kevin_F
    Dec 1, 2004
    246
    So far it seems that Panomax is the preferred brand, anyone have any others? Any experiences with Belkin?
  7. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hey Kevin,
    I also have a single pole Belkin surge protector for my TV in the theatre. So far, so good. No problems with spikes, surges, dirt or power colouration. Not too sure about multi-tap bars though.
    Cheers,
    Andrew
  8. Kevin_F
    Dec 1, 2004
    246
    Thanks Andrew, the prices of the Belkin multi-tap seem better than the Panomax or Monster (I am boycotting Monster anyway), so I was curious to hear from anyone that may have it.
  9. john.michael
    john.michael Agent
    Aug 23, 2004
    28
    I just went to the Panamax site and saw that the Panamax 5510 maximum current rating is 15A.
    However, my brystons 3b st and 9bst will draw up to 25A!!!!
    What should I do to protect them?????
    Moreover, the Velodyne DD-12 that I am planning on using has a 12A fuse. So, only on those 3 pieces of gear I should have 37A. I am going to be bankrupt if I try to protect it all.
  10. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hi Kevin,
    No problelm. Belkin makes all types of products, whereas Panamax basically focuses on power conditioners and surge protectors (I'm sure there are other products as well, but I can't think of them) [​IMG] That's where their pricing comes into play - a 'boutique' maker of excellent products.
    Yes, I know Monster Cable makes lots of products like Belin, but they're just wayyyyy over priced!!!
    When you buy your protector, just make sure it's rated to handle all of your power requirements plus some extra juice.
    Cheers,
    Andrew
  11. Kevin_F
    Dec 1, 2004
    246
    What exactly should I be looking for Andrew?
  12. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hey John,
    You'll have to look at getting two 15amp lines to your rack to provide enough power for your amplifiers, and you'll have to get surge protectors / line conditioners to protect your gear.
    You mentioned that you have a lot of brown outs and so forth - and for that I would really recommend a UPS that would allow you to shut everything down properly instead of crashing when the power goes out.
    I'm sure other people will have other suggestions as well.
    Cheers,
    Andrew
  13. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hey Kevin,
    Figure out how much power you are drawing, what you want to protect and what your budget is and then decide what it is you want. For example, as far as I know, Belkin doesn't make rackable models.
    Start with that and go from there.
    Cheers,
    Andrew
  14. Kevin_F
    Dec 1, 2004
    246
  15. Levesque
    Levesque Supporting Actor
    Mar 21, 2002
    586
    john.michael
    The Panamax 4400 is rated at 20A. I use it for my amps on a 20A dedicated circuit. And a Panamax 5510 for the rest of the equipment.
    http://www.panamax.com/products.cfm?...il&id=209&ly=h
    So if you could run a dedicated 20A line to your rack, you could use the 4440 for those amps.
    And by the way, if your have an average size room, and don't run your speakers to large, 15A would be enough for those 2 amps. I did try my Bryston 4BSST (2X350W) and Anthem P5 (5X325W) on the same 20A circuit, just for fun, and at a really high SPL level, and there was still some juice left on that 20A (speakers to "small", medium sized room).
  16. john.michael
    john.michael Agent
    Aug 23, 2004
    28
    Lévesque,
    Thanks for your input. Are those systems also voltage regulators?
    I think I become dumb once I start reading the specs of those things.
  17. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Kevin,
    Cool! Thanks. I didn't think they did, but alas, I stand corrected [​IMG]
    Cheers,
    Andrew
  18. Parker Clack
    Jun 30, 1997
    12,220
    75
    9,110
    Kansas City, MO
    Parker
    Andrew:
    I heard that you were actually sitting when you were corrected. [​IMG]
    Great advise from all on the conditioners and UPS. What do you think of TrippLite products? An example of one is here.
    Parker
  19. TimRP
    TimRP Stunt Coordinator
    Feb 9, 2004
    115
    If you know what a MOV is, and you know how they work, you probably wouldn't want them in your system. Get a series mode surge protector. Brickwall, Adcom, and a few others produce them.
    http://www.smarthome.com/4401.html
  20. Andrew Stoakley
    Feb 27, 2004
    159
    2
    110
    Andrew Stoakley
    Hey Parker,
    Ok, I guess I 'was' sitting at the time of the writing, but, there have been cases when I was standing and writing too :wink:
    I had never heard of the Tripp-Lite product before, mostly because I have been really, really happy with my Panamax Max 500.
    The one thing I have noticed, which I find really funny is the fact that once Monster Cable came out with colour coded outlet plugs, everyone else in the field seems to have done the same. It's like they think we can't figure out where power cords get plugged in if it doesn't have a label. Ah well, maybe it's just me [​IMG]
    Cheers,
    Andrew
