Sunfire Clear Glass Amp Stand - 3 avail (1 Viewer)
Grace
3 glass amp stands w/ brownish tint avail w/ rubber feet. these comes standard with sunfire equipment but i have ridded the equipment and kept the stands. here is your chance to have an isolation platform for less!
dimensions: 14" W x 18" L x 1/4" D
$99/ea firm
email [email protected] if interested
see my audiogon feedback under 'greys2k'
Arthur S
So Grace
When you say 14 inches high and 18 wide do you mean that this is a piece of glass that is 18 inches wide, 14 inches deep , and maybe half an inch thick?
Artie
Grace
1/4" thick
specs updated
fyi - i put my 100lb krell TAS amp on it w/ no problem
Arthur S
Thanks Grace
I think I know exactly what you have now. They are nice to keep equipment from sinking into the carpet so as not to impede air circulation. And the equipment can have a larger footprint than the glass because only the feet of the equipment need to sit on the glass.
Please feel free to use my language in your ad.
Artie
mikezerby
