Seth V
- Oct 21, 2002
I recently purchased a Sunfire Cinema Grand Signature series II for$2,395. I'm very happy with the sound quality that this 5 channel amp provides, it works great with my Martin Logan setup. As a new owner of this amp, i'm not all that familiar with it.
On the back right side of the Sunfire it has a small switch that you can turn the amp on, off or set it to "auto". On auto it turns the amp on when it senses a signal. Although this function does work, I have to turn the volume up a bit on my receiver(i'm using it as a pre-amp) for the amp to turn on. Is this normal? Another thing that i've noticed is that the top of the amp stays slightly warm when not in use. It doesn't matter if the switch on the amp is in the "auto" position or off( again is this normal?). What i'm gathering is that the unit is constantly drawing power even if the switch is set to off.
Just a few more questions? I have all my equipment connected to a Monster Power reference power center 5000. Is it safe to connect the Sunfire amp to the Monster Power, and will it degrade the sound?? Should I leave the amp on all the time or have it turn on and off automatically?
I really like this amp a lot, and want to get the best performance I can get out of it. Any help you all can give would be appreciated very much.
___________________
Seth
___________________
Seth
