Sum Of All Fears - no insert?
Discussion in 'Archived Threads 2001-2004' started by Andrew Bunk, Oct 29, 2002.
  1. Andrew Bunk
    Andrew Bunk Screenwriter
    Nov 2, 2001
    1,825
    I just picked up Sum Of All Fears, and there is no chapter listing insert. Seems strange for a "Special Collector's Edition". I know a lot of lower end MGM titles don't have inserts, but this seems strange.
    Can anyone confirm that they did get an insert?
    Thanks...
  2. Jeremy Allin
    Jeremy Allin Supporting Actor
    Oct 6, 2001
    895
  3. Andrew Bunk
    Nov 2, 2001
    1,825
    Thanks for the info...
    Is it just a one piece with the cover on one side and the chapters on the other, or is it a booklet? If it's just one piece I can probably live without it.
  4. Thane
    Thane Stunt Coordinator
    Jun 3, 1999
    112
    Mine was just as you described...one piece with the cover on one side, chapter listings on the other.
  5. Andrew Bunk
    Nov 2, 2001
    1,825
    Thanks for that-not worth the trouble of an exchange-I'm not much of a chapter hopper.
  6. David Lambert
    David Lambert Executive Producer
    Aug 3, 2001
    11,380
    38
    BTW, I got an insert, too.
  7. Drea Bruss
    Drea Bruss Extra
    Oct 19, 1998
    18
    Hey guys, can you tell me what the UPC code is on your copy of Sum of All Fears. The reason I ask is that while entering it into DVD Profiler,I noticed the UPC is 9736-33722-4 and the UPC on the copy I have is 9736-33722-2. Checked a couple of places on the net and they all list it as 9736-33722-4. Is it common for them to use more than one UPC code?? One other weird thing is that the UPC code has a pink tinge to it rather that black on white.
    Thanks.
  8. Tom De Rosa
    Tom De Rosa Stunt Coordinator
    Jun 30, 1997
    77
    9736-33722-4 with an insert.
    DO you have a sticker UPC over the rear cover UPC?
    Where did you buy it?
    Anyway, if the disc is good(no bootleg) you can change the UPC in DVD Profiler if you want do, or wait for someone to add that UPC to the database, since I don't think there is a world-wide conspiracy to give you a unique UPC.[​IMG]
  9. David Lambert
    Aug 3, 2001
    11,380
    38
  10. Drea Bruss
    Drea Bruss Extra
    Oct 19, 1998
    18
  11. David Lambert
    Aug 3, 2001
    11,380
    38
    The different UPC code probably mark the difference between "Knogo" copies, "Sensormatic" copies, and "No Security Tag" copies.
    Most places use the "Sensormatic" security tag system, so that's what we're used to seeing in our DVD cases.
  12. David Von Pein
    David Von Pein Producer
    Feb 4, 2002
    5,748
    10
  13. David Von Pein
    Feb 4, 2002
    5,748
    10
    A bit off-topic here but.....
    Speaking of odd UPC codes....Anybody else have Die Hard 2 with code #24543-02148?
    Upon entering said # into DVDProfiler, it shows it as Die Hard 3, not DH-2. Curious huh?
    They show 24543-02149 as DH-2 (which is the # I was forced to use, since it's the closest to mine).
    I also noted that all the Die Hard UPC codes seem to be blocked out, upon viewing the covers on Profiler. They've pasted another number in white over the top of the UPC. But not the usual 10-digit number associated with UPC's. Very strange I thought. Anybody know why the musical-chairs with these UPC's?
