suitable speakers for this amplifier vs speaker set.
Discussion in 'Speakers & Subwoofers' started by dudanpudi, Mar 12, 2017.
  1. dudanpudi
    dudanpudi Auditioning
    Mar 12, 2017
    2
    abby sinha
    I have an amplifier of 20w RMS output and 4ohm impedance, it is stereo amplifier,
    images:-
    front:- https://s8.postimg.org/93xfycy2d/IMG_20170312_142056.jpg
    back:- https://s29.postimg.org/kgmgzz4k7/IMG_20170312_142146.jpg
    should I purchase 2 speakers for this amplifier or it will be better to purchase a 2.1 speakers set like this one?
    http://www.amazon.in/gp/product/B01BL6PM18/ref=s9_dcacsd_dcoop_bw_c_x_1_w
    or this one
    http://www.amazon.in/gp/product/B0154M6J2Q/ref=s9_dcacsd_dcoop_bw_c_x_2_w
    4000 indian rupees is the maximum amount which I can spend. lol, sorry for this constraint. but even spending 4000 is much for me.
    if i should purchase speaker for amplifier, can anyone suggest me some speaker from amazon.in?
    i found some passive speakers like these
    4ohm, 9 watts :- http://www.amazon.in/gp/product/B00LABTLLC/ref=s9_dcacsd_dcoop_bw_c_x_7_w
    8 ohm, 16 watts :- http://www.amazon.in/gp/product/B00Z68X788/ref=s9_dcacsd_dcoop_bw_c_x_6_w
    thanks
  2. ArmSC
    ArmSC Supporting Actor
    Mar 26, 2014
    869
    130
    610
    Coastal SC
    Tony
    Welcome to the forum. I'll try my best to point you in the right direction.
    Is this setup going to be used just for music or in a home theater roll?
    What are your sources going to be?
    Is this for the bedroom or a living room?
  3. dudanpudi
    Mar 12, 2017
    2
    abby sinha
    It will be used for music, that's all.
    the sources may be my amplifier itself, as it have a pen drive reader and can play songs from it and LED TV.
    i will use it in my living room, its size might be 12*16 feet approx.
  4. ArmSC
    Mar 26, 2014
    869
    130
    610
    Coastal SC
    Tony
    Just looking around Amazon and passive speakers are so expensive in your country. You can try the speakers that you linked but I'm pretty sure they are going to sound thin and weak. I'm just not sure that passive speakers with that amp are the way to go. For example a set of Micca MB42x are 12,205.00. These would be entry level speakers that I would recommend for a small system. The slightly larger Pioneer BS-22 are 22,000. With a budget of 4,000 I think it's going to be tough.
    Knowing this I think a set of computer speakers or something like that would be the way to go. Take look at these.
