Suggestions on where to start looking for RPTV (1 Viewer)
David_Moechnig
I've been contemplating upgrading my 27" Toshiba CRT tv and getting a RPTV. I know I want something with HD compatability but don't want to spend an arm and a leg on it either. Are there any particular brands and models that I should look at first. What about a good website that has a lot of technical information RPTV's. Thanks.
Ottis Fletcher
I have the Sony KP46WT500, and the picture is good, its incredible after using Avia.
All opinions from here down are after using Avia.
DVDs look better then I have anticipated (with a progressive scan DVD player). Skin tone is life like, and real depth is added to a lot of scenes. I cant see any flicker problems that normally occur with tiny patterns, like wall paper or shirt designs.
I recently bought a HDTV Tuner STB and an antenna, 1080i images on this set are unbelievable.
I have AT&T Digital Cable a few channels are all most unwatchable after viewing HDTV and DVDs, but its not many and they are mostly under 100. Many of the upper channels rival DVD quality (through S-Video). I plan on getting a satellite dish after my tax return to get more 1080i sources, especially Discovery HD Theater.
Keep in mind that this set down converts 720p to 480p. I was going to take this set back and get a bigger one, but after reading many reviews and doing quick comparisons with other Sony TVs on the same settings the KP46WT500 just looked so much better.
All in all I am very happy with my purchase, I would recommend with out hesitation to anyone who is looking for RPHDTV in the $2K price range. One more thing for the price you can get a much bigger set 55 inch plus. But the PQ from the Sony makes it well worth purchase. I know several people with different models, brands, etc. even after using Avia and watching DVD's or HD on their sets the PQ doesn't even come close to to the KP46WT500.
ManW_TheUncool
His Own Fool
The BK
ManW
I suggest deciding on a ballpark figure for your budget first and then the TV size you believe you'll need. Given that budget is a real consideration (maybe
Ottis Fletcher
You don't want to go cheap on a TV. It would be better to spend $2k+ and get a good set that will last and has the features and PQ to stand the test of time (somewhat), then it would be to go cheap. I mean if your going to spend $1,200 on an alright set, why not spend a few more hundred and get a great set?
I'm not trying to push the set I have on you. You can maybe use it as a starting point to base your decision. There are many many other really great TVs in that price range, I can speak from experience on the one I have. Look around, read reviews, check prices, etc. till you find something that meets your needs.
