suggestions on 32 or 34" HDTV
Discussion in 'Archived Threads 2001-2004' started by brian tees, Dec 1, 2002.
  1. brian tees
    brian tees Extra
    Oct 20, 2001
    23
    friend of mine is looking to buy a 32 or 34" HDTV, looking for any advice and/or good deals
    he's looking to spend around $1,500...but he's willing to spend a bit more if it's worth it
    thanks
  2. RoyGBiv
    RoyGBiv Stunt Coordinator
    Apr 10, 2000
    229
    I have the 34" Toshiba which you can now get for about $1800. It is a direct view set with a great picture. I think it's definitely worth the money, and if this is the size your friend is interested in, one he should consider. The Sony is much more, and I don't think the picture is any better.
    SMK
  3. Chuck C
    Chuck C Cinematographer
    Jan 6, 2001
    2,224
    the 32" sony hs500 would fit the bill. HDTV and $1,500.
  4. Claire Panke
    Claire Panke Second Unit
    Jul 5, 2002
    411
    4
    110
    I got the 34" Philips 9818 for $1550 delivered from Harton Innovations. Nice set. Glad I went widescreeen.
