Suggestions for Very Efficient Center Channel?
Discussion in 'Archived Threads 2001-2004' started by Leon O, Mar 4, 2002.
  1. Leon O
    Leon O Stunt Coordinator
    Feb 2, 2002
    77
    Hello All,
    I currently have Paisley SPL Monitors (purchased 1985) for mains. They are full range and have a rated efficiency of 96.5 db. I'm looking for a matching center.
    I currently have a Klipsh RC3 for the center, but since I've moved to a Marantz receiver & Adcom 545 for mains, I've can now tell that the Klipsh are much brighter than my Paislies.
    Are there any other quality brands that are both efficient and more neutral in sound?
    Has anyone else got experience with Paisley speakers?
    Leon
  2. ColinM
    ColinM Cinematographer
    Dec 9, 2001
    2,050
    Perhaps one of the Infinity models, SM center. 93db.
  3. Tony Meconiates
    Tony Meconiates Stunt Coordinator
    Jan 21, 2002
    188
    another vote on the infinity suggestion.... back in college I used to have a couple inifinity SM 255's taht were extremely efficient.... Their whole SM series is very efficient
  4. george king
    george king Supporting Actor
    May 29, 1999
    625
    The Kef centers are efficient and wonderfully natural. Also, with the coaxial design they have great off axis response.
    Hope this helps.
  5. Leon O
    Feb 2, 2002
    77
    Thanks Guys, I'll check 'em out.
    Leon
  6. Troy_K
    Troy_K Stunt Coordinator
    Jan 20, 2002
    87
    I will also suggest you run a phantom center. This will give you the best results if you sit on-axis. It is so important to have a matching center, and even dedicated ones fall way short of phantom mode. It's also free to try!
    Troy
