Suggestions for OTA DVR?
Discussion in 'Playback Devices' started by Alf S, Mar 31, 2017.
  1. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,476
    627
    4,110
    Alfer
    Yes, we took the plunge. Well, I should testing the waters for a few months. Read more here:
    https://www.hometheaterforum.com/community/posts/4474459/
    So does anyone else use an OTA DVR that doesn't charge monthly fees along the lines of say the Channel Master or Tablo?
    I'm leaning toward the Tablo 4 tuner model but I see I do need to pay for a guide. Does anyone use a Tablo or Channel Master? If so, what are you thoughts? Worth it? Not worth it? Any major issues?
    Tablo DVR: https://www.tablotv.com/
    Channel Master: https://www.channelmaster.com/
    If you had to chose, which one would you opt for any why?
    Thanks for any input you have.
  2. DaveF
    DaveF Moderator
    Mar 4, 2001
    20,986
    2,959
    9,110
    Catfisch Cinema
    Dave
    Personally, having not researched DVRs in four years, I'd do one of three things:
    * Buy a new TiVo Bolt 1TB with Lifetime plan (upfront cost, no monthly) and a DIY hard drive upgrade straight off
    * Buy a used TiVo Roamio with Lifetime plan
    * Build an HTPC DVR with Emby or Plex as the server.
    I don't know anything about Tablo or Channelmaster, as I've not looked at OTA-only DVR options in at least four years.
  3. David Norman
    David Norman Producer
    Oct 12, 2001
    4,737
    1,595
    4,110
    You weren't possibly using an old TIVO 2 or 3 by chance?
    Tivo just sent out deal to get a Transfer of Lifetime plan from an old (still active) TIVO 2 or 3/HD for $99 on a new Bolt purchased from Tivo.com with a promo code. The Tivo 500 or 1Gb 4tuner has the ability to tune OTA.
    A $300 box with a LIFETIME plan with functionality of TIVO is a pretty good deal. The normal Lifetime with this unit with be a minimum of $500+cost of the Unit so $300 vs $650+. They tend to hold their value pretty well too, allows access to Hulu, Netflix through the box.
    Easy enough to pop a new up to 3TB HD into the cheapest unit to increase recording.
  4. Alf S
    Alf S Banned
    BANNED
    Apr 23, 2000
    3,476
    627
    4,110
    Alfer
    Forgot to follow up that we ended up getting the Roamio OTA and it's feeding a Mini Tivo. Works perfectly.
    DaveF likes this.
  5. Steve_Smith
    Steve_Smith Stunt Coordinator
    Jan 16, 2004
    104
    33
    10
    Arizona
    Steve Smith
    Glad your setup is working perfectly, I was going to add that I looked into going a DVR for OTA and realized it all seemed to cost monthly fees so I ended up buying WinTV 8 for my computer and I've used it ever since for recordings, has full OTA schedules and timer for 2 different recordings at once.
