Suggestions For Best Reciever for $1,000 or under
Discussion in 'AV Receivers' started by MarshallSlate, Aug 18, 2003.
  1. MarshallSlate
    Aug 17, 2003
    30
    right now i have a Yamaha HTR-5650, but i got enough money to buy one that cost at most $1,000...might push for $1,200 and i was wondering what everybody thinks would be the best reciever to get for that price that handles 6.2 or more.
  2. Wayne Ernst
    Wayne Ernst Cinematographer
    Feb 24, 2002
    2,588
    If you like Yamaha, how about the new RX-V3300? This is towards their high end and can be found for $800 + shipping on Ebay.
  3. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    Since you ask...the 7.1 Denon 3803,lotsa power and features,also very good stereo music,about $900.00.
  4. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    Denon 3803, Pioneer 45TX, or the new 53TX
    DJ
  5. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    I third (or at least second and a half) the 3803 recomendation. I'd also consider the Harman Kardon 7200 which is on sale at one call right now for just barely a little over $1000 shipped. The amps in the HK are definitely better than the Denon's, but the Denon arguably could possibly actually have a better pre/pro section (and you could always add an amp later on down the line).
  6. Adam_Reiter
    Adam_Reiter Second Unit
    Oct 7, 2001
    461
    I third the recommendation for the Denon 3803. However, you can get one Denon Factory B-stock from Dakmart. The ONLY ebay authorized seller (full Denon warranty) for $809. They are certified from Denon to work as BRAND NEW.
    You wont beat that deal anywhere.
  7. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    I like my HK, after I heard everything at the store from around $300 to up to $800 I liked the HK the best, it sounded much cleaner than the Onkyo, Yamaha, Denon, and Sony.
    I like the HK the best, it is very clean sound and I like it.
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
  9. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    Get the Rotel 1055. There's lots of Club Rotelers that switched from Denon to the better sounding Rotel. Here's one recent example
  10. MathBrisk
    MathBrisk Extra
    Jul 30, 2003
    16
    NAD T762.
  11. Mark Russ
    Jun 23, 2002
    341
    I don't dispute for one second that the Rotel, HK, and NAD are better amps than Denon's in the 3803, thus they are all more "musical" as is. However, if he was eventually planning on adding an amp, I honestly don't think any of the others could touch the 3803 as a pre/pro. It simply has more processing power.
  12. Andrew Pratt
    Dec 8, 1998
    3,806
    Mark I used to think the same thing until I tried replacing my denon receivers with Rotels.
  13. Mark Russ
    Jun 23, 2002
    341
    Andrew,
    did you extensively audition the Rotel against the Denon head to head specifically as pre/pro vs pre/pro on a level playing field with identical sources, amps, speakers, wires, cables. etc?
  14. Andrew Pratt
    Dec 8, 1998
    3,806
    No not against the Rotel..I went from Denon to Sony pre amp to Rotel and each was a step up. For movies you might not notice as much but you should for music.
  15. Mark Russ
    Jun 23, 2002
    341
    I have no doubts that the 2 channel preamp section of the Rotel is probably better than Denon's. However, at movies, I still say the 3803 would be better.
  16. Yogi
    Yogi Screenwriter
    Jul 25, 2002
    1,741
    I fourth the 3803 recommendation. Clean neutral/warm sound. Gobs of power. Tons of processing features. For HT you will be hard pressed to do better than it for less than a grand.
  17. BobJ
    BobJ Stunt Coordinator
    May 6, 2002
    178
    I second the Rotel suggestion at this price point. It's very much worth looking into.
