I have a setup I'm trying to get working at my house that's driving me bonkers.
I have an in-wall receiver system upstairs in my house. It has available optical and analog input.
I want to run a line-level signal from my main AV stack to it so both levels of house have the same thing playing if we want. There's already conduit running between the two points, so I should be able to pull almost any kind of cabling required.
I tried using optical, but it turns out that is only rated for 5m without repeaters required. That's a lot of repeaters and I can't get that many in without opening the walls and doing crazy things to get power available anyway.
Running a line-level audio signal 75' through the walls is almost guaranteed to run into problems with interference pickup. Since I don't know where the power and conduit all run exactly, I have to assume they'll be in close proximity often.
So I'm looking for recommendations on how I can send a line-level signal about 75' through very likely hostile conditions.
Thanks.
Thanks.
