Suggested cleaner for RPTV
Discussion in 'Displays' started by Rick A., Nov 25, 2003.
  1. Rick A.
    Rick A. Auditioning
    Aug 16, 2003
    9
    during a search of the forum I found the Monster Cable cleaner. But, is there any household cleaners that work well? Anything I should stay away from?
  2. MannyE
    MannyE Stunt Coordinator
    Sep 22, 2000
    229
    Which part do you want to clean?
    Regardless, I never use anything more aggressive than a moist sponge.
  3. Rick A.
    Rick A. Auditioning
    Aug 16, 2003
    9
    The screen is what I'm looking to clean. My 2 year old likes to point to the cartoon characters and during a recent movie I really noticed the smudges.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Distilled water, mild detergent, and an optical-grade polishing cloth (two of them, actually). If distilled water and detergent are too much to deal with, get an amonia-free spray solution for cleaning eye glasses or computer monitors.
    Apply solution to cloth, and then wipe the screen in gentle up-and-down motions. Use the dry cloth to wipe away any streaking.
