Subwoofers?
Discussion in 'Archived Threads 2001-2004' started by ChristopherBer, Mar 11, 2003.
  1. ChristopherBer
    ChristopherBer Stunt Coordinator
    Dec 23, 2002
    74
    Where did subwoofers originate from? Who invented the first one? What is the history of them? Thanks...[​IMG] [​IMG]
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    They go way back, Christopher.
  3. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
    Jack, I disagree with you somewhat. I've been into audio and video since the mid 60's and subwoofers for residential use is a fairly recent phenom. Woofers? Sure they have been around forever. Subwoofers? I believe they only became popular with the advent of home theater in the late 80's.
  4. Garrett Lundy
    Garrett Lundy Producer
    Mar 5, 2002
    3,764
    I believe the russians first invented the subwoofer when they put a dog in a submarine.
    Har har har....
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Rick, think back to 1968: The original Infinity Servo-Static I electrostatic speaker system consisted of two largish electrostatic panels crossed over to an eighteen-inch subwoofer (and "subwoofer" was the word used by the company). And that woofer went low.
    There was also, during the 1970s, the Hartley subwoofer (which went up to, if I recall, 24 inches). The Hartley made a lot of news when Mark Levinson included it in his so-called Decca/Quad/Hartley hybrid speaker system (two original Quad electrostatic speakers per side, mated with two Decca ribbon tweeters per side; both panels crossed over to a pair of Hartley subwoofers).
    And who can forget that darling of the high-end audio crowd, perhaps the most famous subwoofer of the 1970s: the Janis W-1 subwoofer.
    Also, in 1976, Dahlquist introduced the DQ-1W "subwoofer" to mate with its legendary DQ-10a phased-array dynamic speaker system. Though Dahlquist literature referred to this 10-inch driver in a sealed enclosure as a "subwoofer," it was not, rolling off as it did by 3 dB at 40 Hz.
    Then Polk Audio, in 1979, introduced the LF-14 "subwoofer" system (two six-inch drivers venting into a 14-inch passive radiator).
    Need I go on?
    (Throughout this entire era, no one used the phrase "home theater.")
  6. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Oh, and even before then, in the 1960s, Electro-Voice (remember them?) used to market a huge all-in-one speaker system called the Electro-Voice Patrician, whose bass output was handled by a massive 30-inch woofer. E-V also marketed this 30-inch driver separately as (you guessed it) a "subwoofer."
  7. Tim Fennell
    Tim Fennell Stunt Coordinator
    Jul 11, 2002
    138
    Don't forget the SenSurround Subwoofers that came with the movie Earthquake. That goes back to 1974. Those speakers were 18" if I remember right.
  8. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    I think SVS made the first real subwoofer. [​IMG]
