subwoofer
Discussion in 'Archived Threads 2001-2004' started by Matt Weldy, Feb 15, 2002.
  1. Matt Weldy
    Matt Weldy Second Unit
    Feb 4, 2002
    335
    would it be a problem to enclose a front firing sub in a cabinet. as long as when I am using it the doors are open so it can breath.
  2. Kerry Hackney
    Kerry Hackney Stunt Coordinator
    Oct 18, 2000
    206
    Wellllll, there are some "ifs" that come into play here. IF you don't also have a TV in the cabinet that could be damaged by a non-shielded sub.
    IF the cabinet is very well braced so that it doesn't resonate. Maybe build the section of the cabinet housing the sub with double thick walls or even make the innerwall from MDF. Also, making sure the sub compartment is sealed.
    And IF the vibration from the sub doesn't cause your electronics / players problems.
    I have seen it done in several custom installs but these are things to keep in mind.
  3. John Geelan
    John Geelan Screenwriter
    Oct 11, 2000
    1,087
    it could work.
