Tim Simko
- Mar 13, 2003
Should I wire my front L/R speakers thru my twin Velodyne subs (FSR-1200's) or should I hook up my subs & speakers directly to my Yamaha DSP-A1. If a direct cable hookup for the subs is recommended, what type of cable would you suggest?
Also I've got bi-wire capability with my fronts & center. I want to try this & see if it sounds better. How would you terminate the twin lines at the amp?
Thanks in advance. Glad to join all of you!
