Subwoofer starts popping during heavy action scenes?
Discussion in 'Speakers' started by BryanPAZ, Oct 16, 2005.
  1. BryanPAZ
    BryanPAZ Auditioning
    Oct 4, 2005
    Has this happenned to anyone else? Every time I think I have it adjusted right, I'll be watching a movie with a lot of gunfire, action (anything with a lot of bass), then all of a sudden the sub makes this loud popping noise. If I turn it off, then on again, it will go back to normal until the next action scene. I have an older Velodyne sub with it's own amp, and the receiver I'm using is a new (about one year old) Yamaha RxV550.
    The funny thing is, if I set the Yamaha for "all channel" and crank the sub as high as it can go, it will shake a lamp off the table and there is no breakup or popping at all. I think the sub is fine, maybe just a setting is off or something?
    Any suggestions?
    Thanks!
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    As crazy as it seems. I think this is a cable or connecttion issue. Let us know what you find.
