Ed O'Neill
- Mar 20, 2003
Ok the theater is built and external cables/wires are ordered! YEAH! down to the set-up.
Before anyone starts...I am a Die hard Cambridge Soundworks fan. I stared using them way back in 1994 and have upgraded and upgraded with their trade-up program. I know some of you guys will say there are better speakers out there, but I love my set up.
Now having said that I just bought my powered subwoofer, and I am looking for suggestions for the best way to hook up my speakers/system. You see I have the original ensemble series front speakers 2 satelites and two non-powered subs. Now I know that Cambridge sound works and other companies usually have a powered subwoofer and the satelites. This means you should set your amp to small speakers.
Here is the questions:
1.In my situation Should I use the 2 non powered subwoofer and set it to large(full range)
2. For the center channel should I use large or small setting? I was always told that the center speaker is the most important so shouldn't it be set to recieve all the signals.
Thanks in advance,
Ed
Thanks in advance,
Ed
