Subwoofer Recommendations (1 Viewer)
Steve_H
I am in the process of setting up an HT in a mid-size room approx. 15x17. Speakers are all Paradigm, Monitor 7 front, Monitor 3 rear, CC-170. Looking for a decent powered subwoofer to go with this set-up.
This equipment/room is strictly for movies. My 2 channel music system is in another room. So, the sub would just be to enhance the sound effects of movies.
How are the Paradigm subs? PDR-10,PDR-12,PS-1200? I have also read about the HSU subs. I'm trying to keep the price around $500.
Any suggestions would be appriciated.
Thanks.
Marty M
Of the three Paradigms you listed, I think the PDR-12 has a bit tighter bass. If you can swing an extra $200 or so, I highly recommend the Paradigm PW-2200. I have been very pleased with this sub.
J
John Morris
Hmmmm... now what subs could we possibly recommend???
Check SVS first. If too expensive, check out Dharman . If still too expensive, I'd recommend you visit the DIY section of this forum for help in building your new subwoofer.
Take Care,
merc
DFAST, 5C, DVI, HDCP, SafeAudio, Macrovision and Lewinski!!!
Jack Gilvey
At that price point for a powered sub, I'd go with the Dharman that John mentioned. It's about $550 delivered 'till the middle of August (there's a 15% off deal going on, see hometheatertalk.com for details).
Tom Vodhanel
I'd also toss the HSU VTF_2 into the mix,
Look for it's performance in reviews ranging from Tom Nousaine to WSR to AUDIO to SGHT...it's really an amazing performer for a 10" woof.
TV
AlohaTiger
