eddieZEN
- Nov 30, 2004
1. Are most subs either better for music or for HT, rather than being equally good for both?
2. What qualities/specs/features would you look for in a music-oriented sub?
3. What qualities/specs/features would you look for in a HT-oriented sub?
4. I get the impression there is some sort of rivalry between SVS and Hsu on many audio forums, and that the SVS is said to be better for HT and the Hsu better for music. Agree/disagree?
5. Comparing specific models and pricepoints, it does appear that SVS offers subs that are bigger, heavier, more powerful, and go lower than Hsu within the same pricepoint. For example, the SVS PB-10 ($429, 20Hz, 60lbs, 300w) seems like a much better value than the Hsu STF-2 ($400, 25Hz, 44lbs, 200w) esp. if one accepts the conventional wisdom of weight being an indicator of quality in most things electronic. Or am I missing something here?
6. For a 80% music (jazz, classical, vocals) and 20% HT user like myself, just how good of a sub do I really need? My HT is 80% low-LFE stuff anyway such as "Sideways," "I Heart Huckabees," "Eternal Sunshine..." dramas/cult/foreign films, for which I often won't even bother plugging in the surround speakers (long WAF-related story on that which I won't go into, LOL).
7. Given #6, also factor in that my listening space is fairly cavernous (700 sq. feet) with 18 foot vaulted ceilings and the sub cannot be placed in any corner. So would the PB-10 or STF-2 suffice, or should I increase my budget?
8. Are there any other subs you'd recommend in this price range, given #6 and 7? I'm currently running Ascend 340s across the front, on a Marantz 5400, with an atrocious JBL e150 sub.
