Gau
- May 18, 2004
this may sound like a noob question, which it it, so laugh if you want to
I bought my very first subwoofer and it arrived yesterday. (Dayton 10" 100w from partsexpress.com) - i have a separate thread about connecting it etc.
I have it connected to a yamaha htr5740.
now, having never listened to a properly setup subwoofer system, i dont know what it is supposed to sound like...
I'm guessing, while watching regular TV, unless the broadcast is in dolbydigital, i wont notice a difference?
while watching dvd's the sub should only kick in during a LFE effect right?
I have my front speakers (my only speakers - paradigm minimonitors) set to small
receivers bass goes only to swfr,
A/V crossover at the default 80,
the subwoofers crossover at 80 also,
phase-default (whatever it came with),
volume on sub - about halfway between min. and max.
i have the Lotr-TT dvd and the SW-trilogy dvd set to play with, and from what i've heard they have good effects. Are there any scenes from those two movies that you guys distinctly remember has having a tremendous bass effect, or is there a decent test dvd i can buy for sound?(nothing outrageously priced)
thanks for helping a novice!
