subwoofer question?
Discussion in 'Archived Threads 2001-2004' started by Binh Vu, Jul 17, 2002.
  1. Binh Vu
    Binh Vu Stunt Coordinator
    Jul 1, 2002
    111
    It's kinda stupid question for most of people here, but I'm so new to the HT.........
    My yammy receiver (HTR-5450) come with a powered sub (75 watts amp, 7") and I kind of need some more bass so, my question is can I upgrade my sub to a bigger one (300 watts amp, 12")???? Will it damage my receiver????
    Thanks a lot!
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    A powered sub will just connect to your reciever by a simple audio interconnect. The receiver won't power it, just send it a signal for the sub's own amp to amplify. You can hook any powered sub (or passive sub and a seperate amp) up to your receiver you want. You won't damage it.
  3. Binh Vu
    Jul 1, 2002
    111
    thanks for your answer, I'll have to get another sub very soon though
  4. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
  5. Brian Burgoyne
    Brian Burgoyne Second Unit
    Jan 9, 2001
    325
    Binh,
    I just responded to your other post where you were looking for a sub UNDER 10 inches. If you are looking for a good sub from 8 to 12 inches, you can't go wrong with the Adire Rava that Bruce mentioned, or a HSU VFT-2, or an SVS 20-35 pci, all under about $500.
  6. Binh Vu
    Jul 1, 2002
    111
    Thanks, too many mentioned SVS. I'll check that out first
  7. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Bruce,
    Are you referring to the NHT 1259? I wouldn't even dream of using that driver today as it's been far outclassed by the likes of the Adire Shiva and Dayton DVC 12" drivers. Unless it's gotten considerably cheaper, it's even more expensive than the other two.
    Brian
  8. Bruce Chang
    May 10, 2002
    283
    Brian,
    I don't know which NHT my friend got, but he got a pretty good price on it. The NHT is very musical and wouldn't mind using it for HT. As far as I know, the bang for the buck sub is the Adire Rava. Or you can build your own box and get a tempest [​IMG]
  9. Brian Bunge
    Sep 11, 2000
    3,716
    Bruce,
    I always build my own! [​IMG]
