Subwoofer Question for B&W 600 series?
Discussion in 'Speakers & Subwoofers' started by Bo-Cephus, Apr 4, 2006.
  1. Bo-Cephus
    Bo-Cephus Agent
    Mar 27, 2006
    49
    Hello,
    Wanted to see if anyone had any suggestions for a subwoofer for my HT audio system - B&W CC6, 602's as main's, 601's as rears. I know what B&W recommends, but are there less expensive alternatives that would "match" w/this setup? Mostly movies 80/20, room is about a 18X20 w/very high vaulted ceiling. Usually not extremely loud volume levels. If you need more info to answer please let me know. Thanks.
  2. Shane Harg
    Shane Harg Second Unit
    Feb 14, 2006
    291
    I have the B&W 600 S3s all the way around in 7.1 w/the LCR60 center, and I personally have the KEF PSW2500 sub, which is a good match for these speakers with its sealed design.
  3. Blaine_M
    Blaine_M Second Unit
    Mar 11, 2004
    400
    I used to have the CC6 and 602s2's. I used an SVS PB-10 with them, worked very well. For a larger room you could step up to a PB-12 ISD or a PB-12 ISD/2, I guess it depends on your budget really, maybe step up to the PB-12 Plus...?
