John I C
- Jan 15, 2004
Great to find this forum! A lot of y'all really know your stuff! Hopefully you can give me some assistance.
I recently purchased a Panasonic SA-XR25 A/V receiver. Prior to this receiver I had a Sony Pro-logic receiver. All is well with the new receiver, but I'm having a problem with my subwoofer's dropping to standby whenever there are no loud sub sounds eg. during dialogue. When it does come back on, many times the sound effect is half over. In other words, it seems like there has to be a fairly high level of signal before the subwoofer will "pop" on.
I have a Sherwood subwoofer, which was connected to my Sony via speaker level inputs. When I got my new receiver, I connected the sub to it via the RCA jack labelled "sub" on the back of the receiver. Now, the sub has only speaker level or line level connections. It does NOT have an LFE connection, just left and right line level.
The Panasonic receiver manual states to use a mono connection to the sub. So I used an RCA cable from the receiver sub out to left in on the subwoofer. When I experienced the problem, I went to Radio Shack and bought a $15 gold-tip "Y" cable specifically for subwoofers. Still the same problem. Sub sounds great for the loud sequences, but shuts off during lower volume parts.
I have the speakers set to "small" in the Panasonic, sub is "yes", and the crossover is as high as it goes (200) I've tried messing with the dynamics settings on both the DVD and the Panasonic receiver. Nothing really helps...And there doesn't seem to be any control on the sub to leave it "always on" or "auto on". And I never had this trouble when I connected to my old receiver via speaker level. One more thing- when I use an analog source in the receiver (like my vcr)the sub works fine.
I'm new to owning a digital receiver, but I suspect that the level of signal provided by the LFE output is not enough to keep the sub on all the time. In my old pro-logic setup, it was getting speaker level, and stayed on. If I use a stereo analog source, it stays on. But if I use DD 5.1 or DTS, it will drop out.
SO...Can the sub out from the receiver provide enough signal to the line inputs on the sub? Is a "subwoofer" cable any different from another high quality shielded RCA cable? Should I "y" the cable or just use left? Is there some kind of small external amp I can stick on the cable to boost signal? Is that even the problem?
Thanks for reading all this, and thanks in advance for any suggestions you might have!
JC
JC
