Subwoofer Problem in Analog 5.1 Mode on Kenwood VR-7070
Discussion in 'AV Receivers' started by Ryan_Walsh, Dec 25, 2003.
  1. Ryan_Walsh
    Ryan_Walsh Stunt Coordinator
    Oct 23, 2001
    86
    For some reason, I cannot get any sound from my subwoofer when trying to listen to dvd-audio in analog 5.1 mode on my new Kenwood 7070. The manual has been less than helpful and am looking for any help from the forum.
    I have 3 pairs of audio cables leading from my analog 5.1 outputs of dvd-a player to the anlog 5.1 inputs on my receiver. Also have a digital coax out from dvd to receiver. The sub is connected to the sub pre-out of the receiver. Receiver is set to 6ch mode.
    Thanks in advace for any help. Merry Christmas.
  2. Rik P
    Rik P Stunt Coordinator
    Aug 25, 2001
    111
    Is your Digital coax going to the DVD6CH "digital coax" input aswell?
    If your DVD6CH input is set up for "AUTO" the digital well always over ride the analog even if there is no output from the digital.
    Try selecting the DVD6CH input to Analog or unpluging the digital coax temporarly and see if that works. If that works you need to move the digital coax to Video 3? or change the DVD6CH input selector every time you listen to DVD Audio.
    Rick
  3. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Don't forget that DVD-A and SACD have subwoofer levels that are approx 10db lower than regular DVD's. Many users have found that if they compensate for this difference that their subs were working all along but just playing way too low.
    Does your player have the ability to crank up the sub level output? Some newer receivers, such as Denon, have a separate sub level adjustment just for this 10 db difference on the External Inputs.
    Try making the adjustment and let us know what you find out.
  4. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I don't know about the Kenwoods, but most receivers switch to an analog direct mode for the preamp inputs.
    My guess is that this is the problem. A number of new hi-res players have compensation for this built in (selectable).
  5. Doug_H
    Doug_H Supporting Actor
    Mar 21, 2000
    586
    It is very common for dvd_A discs to not have a sub track and to a lesser amount a center track even when they say 5.1
    This had me confused when I first started into DVD_A
  6. johnsky
    johnsky Auditioning
    Dec 2, 2011
    set your front speakers to small,i had the same problem with my set up.
