Hi all,
My Martin Logan Dynamo 500 subwoofer has been acting up for a while, and I'm at the point that I need to find a solution. I purchased it from Best Buy in August 2012. Since then I've replaced every other piece in my setup (new receiver, speakers, Blu-Ray player, etc). Also, I recently moved, so I've got a new cable, power strip, etc, so all that is different as well. I can't remember exactly when it started, but I replaced my receiver last July and I know it was a problem prior to that.
Ok, enough history, here's my problem:
Just about every time it goes into standby (there is no permanent on, just off and auto) it will buzz. It's not subwooer hum. It's a very distinct, loud, obnoxious, low, rumbling, buzzing noise. Also, it seems like when it's under very light power (ie. at night when I have the volume low) it will randomly "pop." I share walls with neighbors (less now than before in the apartment, but it's still a townhouse not a house), and the power is generally low late at night, so when it does this I'm sure my neighbors are thrilled.
I've done a lot of searching the web and I've seen threads on ground loop and appliances possibly being the issue, but seeing as how everything is setup at a new place I don't think that's likely. At the old place it was on the same power strip as the receiver. At the new place it's on a totally different outlet. I had to replace the cable with a longer one, so it's not a bad cable. It did it with the old receiver and the new, so I don't think it's the receiver sending wonky signals to it. It doesn't matter what source I have it on. I've unplugged the coax cable and it still pops randomly, but I don't get the buzz.
I hope I've given enough info to help provide a solution. Any help would be much appreciated.
Thanks in advance!
Thanks in advance!
