Subwoofer Plate Amp?
Discussion in 'Archived Threads 2001-2004' started by Richard Fernandez, Dec 27, 2001.
  1. Richard Fernandez
    Richard Fernandez Stunt Coordinator
    Jul 2, 2000
    116
    Which one? Parts Express 250 Amp, Adire Audio 250 Amp, or the ACI PSA-1 200 Amp. I'll be using the Shiva driver.
    [​IMG]
  2. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    I would plan on using the Adire amp unless you plan on modifying the bass boost on the Parts Express amp. The Shiva doesnt need the boost.
  3. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Richard,
    I have two of the PSA1 amps and think that they are excellent. They are identical to the KG5150 that Madisound sells save for one feature. The PSA1 has a toggle switch to defeat the amp's bass boost circuit. That is unless the KG5150 has also incorporated this feature. The last time I checked it hadn't been added.
    The Parts Express amp provides the most watts per dollar and I believe you can order it with the boost defeated. I'd double check before ordering though.
    Brian
  4. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
    Richard, I bought the Adire AVA250 for my Adire Tempest-based sonosub. It has the bass-boost defeated and performs great. The P.E. amp comes with documentation that you can use to change the boost by substituting some resistors. I don't know what the current difference in price is, but if it's small, I'd go with the Adire amp.
