Subwoofer placement
Discussion in 'Speakers' started by ScottHuff, Aug 25, 2005.
  1. ScottHuff
    ScottHuff Auditioning
    Aug 25, 2005
    I am planning on using two car audio sub woofers to be my subs for my home theater system, i have a problem, in order for the car audio subs to work the box has to be..massive, my current plan is to build the box and place it behind my couch, the room its going in isnt that big so that is pretty much the only place it will fit. my question is, does it mess with the sound to have subs behind you instead of in front of you? i read somewhere that they are non directional and theoretically can be placed anywhere in the room. the subs im planning on using are Diamond Audio TDX 12"
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    You might find this to be of interest.
  3. drobbins
    drobbins Screenwriter
    Dec 2, 2004
    1,872
    Dave
    Here is another Link on good multi sub locations and the effect. Doesn't really cover two behind the seating though [​IMG]
    Dave
  4. FeisalK
    FeisalK Screenwriter
    May 1, 2003
    1,245
    is there a reliable way of predicting/guessing where room nodes are going to be, and where two subs could cancel each other out?
  5. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Generally speaking also, car audio sub drivers do not do well indoors. They rely on cabin gain to achieve their levels, which typically translates into less than optimum performance in-room. If they are also 4 Ohm or less, you're going to need a good amp for them.
    Bass is non directional below a certain point, and placement can be quite critical for good response.
  7. MikeLi
    MikeLi Supporting Actor
    May 6, 2003
    945
    What about the other way around. I have a spare SVS 12" woofer (not an ultra just the normal one) Have been thinking of helping my son build a cabinet and get some amps for his small SUV to put it into. Would it work ok and worth the time and effort? Thanks so much.
    Mike
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Might check with SVS on that one, but I don't think it will be an issue. I'm pretty sure I've heard of people doing that. They may even give you some tips on building the enclosure.
  9. Victor Ferguson
    Victor Ferguson Stunt Coordinator
    May 2, 2005
    120
    I have found through personal experience that a single sub placed behind you does not normally work out very good. As far as using a home audio sub in a car, I don't see a problem other than it being 8 ohm and not being driven as well as a regualr 4 ohm sub.
