Paul_Fisher
- Dec 27, 2001
Hello,
This question is basically for people that have the Sony WM-40 sub. Where do you all have it placed in your room? I keep on experimenting and can't find a great place to put it. I had it next to the couch for a while for maximum rumble for movies. Then I moved it to the front next to my main speakers but lost the rumble. Does anybody know a good place to put it where it will rumble the most for movies but yet have tight bass for music? The placement for mine is very limited, I live in a small apartment and I can only use the right side of the room (facing the TV) because the left is the front door. Anybody have any suggestions?? Pictures would also be helpful.
Thanks for replies,
Paul
Thanks for replies,
Paul
