subwoofer placement question
Discussion in 'Speakers & Subwoofers' started by Derek_P, Jan 4, 2004.
  1. Derek_P
    Derek_P Stunt Coordinator
    Dec 30, 2003
    74
    i am building a rectangular home tehatre room.. the dimensions are 16'8" L x 12'9" W. Couch placed about 3 feet from the back wall...
    sound the sub be placed front center or front corner?....or rear center or rear corner?
  2. Johnny Ayala
    Johnny Ayala Stunt Coordinator
    Nov 13, 2003
    183
    I'de go for the front corner....IMO [​IMG][​IMG]
  3. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    Ditto for the FC........but you'll never know what's best until you test it in the room, you may be suprised what may work best.
  4. Derek_P
    Dec 30, 2003
    74
    cool thanks
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i hear this trick works. haven't tried it though....
    1. put the sub where you would normally sit
    2. get on your knees and start crawling around
    3. where you hear the bass the best, that's where the sub should go.
    of course, that could mean the middle of your room. [​IMG]
  6. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    I heard put the sub in your listening position and start crawling around and see how it sounds. Where the bass is the best, is where it should go.
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    doh! ... jesse is right. you're supposed to put the sub where you're sitting position is.
    heh...i'll fix my prior post. :b
  8. Derek_P
    Dec 30, 2003
    74
    what should i use for a subwoofer cable by the way?
    a RCA mono cable or is there something that gives better quality.... and how do you build/make it?
  9. Kevinkall
    Kevinkall Second Unit
    Mar 20, 2003
    331
    I found mine to sound the best in the front left corner. I use a THX Monster sub cable.
  10. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
    If im dealing with a pretty much square room (17.5x19.5) would itmatter whether its left or right front corner? I assume the standing waves would be the same from either.. Am i wrong in this. Also, with a volume of 3300 cubic feet I have two original 20-39cs subs and a Samson S700 amp. Should these be suffucient for this volume?
