Subwoofer phase
Discussion in 'Archived Threads 2001-2004' started by Craig Beierlein, Sep 5, 2001.
  1. Craig Beierlein
    Mar 12, 2001
    47
    If my sub is in the rear of the room and the main speakers are in the front, should the sub phase adjustment be 0 or 180 ?
  2. martin_v
    martin_v Extra
    Jun 5, 2001
    24
    when you hear the most lowest bas, that is the stand that you use.
    my [ Homepage ]
  3. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    The phase adjustment is there to get the bass in the sub to fire as close to the rest of the speakers as possible.
    Turn on something bassy and listen at either setting which sounds "cleaner", would be my advice. Granted I'm no bass guru.
    /Kimmo
