Subwoofer making humm noise.
Discussion in 'Speakers' started by ChrisLazarko, Nov 24, 2003.
  1. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    I have my subwoofer hooked up with EQ to make bring out the lower frequencies. Now the thing is when it is hooked into the EQ it makes a slight humm noise which is only noticeable when your down by the subwoofer. Is this something to worry about or am I ok?
    And the subwoofer is a Polk Audio PSW250.
  2. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    What is the EQ and how is it connected? Is everything plugged into the same outlet?
  3. Lew Crippen
    Lew Crippen Executive Producer
    May 19, 2002
    12,060
    Most subwoofer equalizers work best when used to reduce peaks, rather than boost valleys. I don’t know the specifications on your sub, but it may be that you are trying to boost it past its abilities.
  4. ChrisLazarko
    Aug 13, 2003
    867
    Hmm, well should it even be doing it when nothing is going through to the sub channel? Could it perhaps just be extra noise from power going through the cable that should not be there?
    I would say the lowest this sub can go is about 30Hz, maybe 25Hz if lucky and positioned right. I have the volume on it up about half way, and have the 31Hz on the EQ almost maxed, the 50Hz up as well, and the rest are up just a tad... It sounds good but I don't want to blow the woofer.
  5. Shane Morales
    Shane Morales Second Unit
    Jul 9, 2003
    433
    Do you have a line conditioner? When I plug my SVS right into the wall outlet it hums, but not when it's plugged into the line conditioner. Maybe that's it?
  6. Lew Crippen
    May 19, 2002
    12,060
  7. ChrisLazarko
    Aug 13, 2003
    867
    No line conditioner but there is no humming noise when it isn't plugged into the EQ. Without the EQ everything is alright but unfortunatly it is too boomy at some ranges.
  8. Lew Crippen
    May 19, 2002
    12,060
