Subwoofer kickback with 2 receiver setup.
Discussion in 'AV Receivers' started by Mike Ki, Sep 13, 2005.
  1. Mike Ki
    Mike Ki Agent
    Nov 4, 2004
    49
    I posted this in the subwoofer and speaker section without much response, so I thought I'd try here.
    This is the setup I am running right now, the second diagram.
    http://www.hometheaterforum.com/htf...threadid=228259
    Whenever I turn on the second receiver for my bass shakers, my subs have a loud kickback. Is there a reason for this, is something wired wrong. Everything works fine once they're on it, it's just when I initially turn it on there's a power surge? Any suggestions?
    Thanks Mike
  2. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    It's an old receiver right? They did that. The work around is to turn on the receiver before your subs. Personally, I would not use a receiver for this duty anyway. Too much chance of someone cranking the volume and blowing the shakers. A good plate amp would not cause the problem you describe and they are cheap.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Right as I posted in the other place...
    Tape in and/or CD In, analog inputs are NOT power amp inputs. I just don't do it period anymore.
    There are cheap external amps out there as well, all would be much better than the current configuration.
  4. Mike Ki
    Mike Ki Agent
    Nov 4, 2004
    49
    Thanks Rob and John.
    What do you recommend for plate amps or external amps and where's a good place to get one.
    Thanks Mike
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    On the cheap side of an external amp...
    I like the Audiosource Amp/1A's, do a google, they can usually be found for under $100 for the audiophile grade amp, which is relatively ultra cheap.
    On the plate amps, (not sure how I would integrate one with bass shakers) go to Parts Express, they have a wide selection on them.
  6. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    I use a PE plate amp for my shakers. It was cheap and easy.
